Need help calibrating topsetter 74
vance
Hello everyone,
I am trying to calibrate our topsetter 74 CTP, we are getting lines on the prints on the 45 angle and a deformed dot shape.
This happend after the tech person changed two diodes.
We are using sonora xtra3.
I am following the user manual.
When I screen the focus and zoom test plates, the pattern is not the same as the manual. Do I need to select the pattern before running the screen?
I cant find any prints, but will post here the plate and pattern from manual.
The black patches are 100% density and cant see any lines or dot densities.
I will post some photos here to explain.
Any help here very appreciated.
Here is a test print. The dot shape is deformed.
It's not about calibration, but repair ... smth went bad during the laser diode replacements.
- put the sonora plates aside and run all tests on positive plates (process by hand if needed) so you get proper contrast exposed images
- run a grid test pattern to determine if H or V lines are corrupt so we can better understand what's going on
- find a USB microscope or take pictures through a macro lens and post the results here
- search all non-printing areas carefully for stray pixels.
One last thing, having seen the pictures attached I believe you didn't quite understand how to correctly set values in there ... I'm talking about initial and count values. Your exposure parameters are not right.
Hello Maxon,
I will try that tomorrow and post results.
Could you advise how to set the values? I imagine you mean the set value in brackets?...I understood from the manual that it doesnt effect that tests. Its a Low value and a high value.
I dont have any positive plates at hand. I will try to get some from a neighbour.
Here is a few more tests of all colors.
Problem sorted, we cleaned and greased the endless screw of the laser head and now we getting better result.
