Re: Nexus Total RIP, PDFs and fonts - AAHHGGG
So you have Nexus. You must have Artpro too to have outlined fonts already (fonts outlined during import into a vector workflow). So your fonts are outlined and you have no problem doing that. At least that's a fix. Yes Eskoartwork should fix this problem. Have you contacted them about it?
Let's say they don't fix it. So you have import that can take in a PDF and outline fonts, so you can print it. Then, if type changes need made after that, you could open the original PDF (fonts embedded) in Iceni Infix2 and do the type changes, save as a new name, import the "fixed" PDF into Artpro, and copy just the changed type and paste onto the previous version of the Artpro document, and save as a new document. Or get Neo to be your PDF editor (which like Infix2 uses the PDF's embedded fonts to make type changes, but Infix2 costs less than a hundred hotdogs while Neo costs thousands of hotdogs, when about the only difference I've seen between Artpro and Neo are that Neo can use the PDFs embedded fonts to do type changes while Artpro can't). Not the best workaround, but it'll work.
Don
