No view file in PowerLayout
cnumb
Had this problem in 8.1 ver. 4, thought that the upgrade to PowerLayout 9 ver.2 was going to fix. No such luck.
Basically when you apply the graphics into the repetition layer of the layout. it does not create a view file. The file is there though because you can see the colors, ie. 5th colors, in the separations palette.. So inevitably the only way to see if your work is centered and bled the way you prefer, is to view the final plate file at the CTP front end.
Is anyone else having this problem and if so is there a solution?
Did you saved the single ArtPro file with a "Separated preview"???
This option is available through the Preferences - File - Save separated preview by default or within the Save Dialog.
If you are using Nexus workflow, go to the "Create Link" module. Lower the resolution...that does it for us.
beck
