Sustainable
Banned
D Ink Man did make us all believe he was about to help in a very big way on this subject and chose to retract his offer. At least give us a reason for the retraction.
A poor farmer one day discovers a glittering golden egg in the nest of his pet goose. At first he thinks it must be some kind of trick. But as he starts to throw the egg aside, he has second thoughts and takes it to an appraiser. The egg is pure gold. The farmer can't believe his good fortune and becomes even more incredulous the following day when he discovers another golden egg. Day after day, upon awakening, he rushes to the nest to find another golden egg. He becomes fabulously wealthy. It all seems too good to be true.
But with his increasing wealth comes greed and impatience. Unable to wait day after day for the golden eggs, the farmer decides to kill the goose and get all the eggs at once. But when he opens the goose, he finds it empty. There are no golden eggs and now there is no way to get any more. The farmer has killed the goose that laid them.
Bob Peterson posted this 11-25-2008
The section in brackets is the important part
Regarding the chalking. You are correct in that one type of chalking is caused due to the varnish/vehicle portion diving into the substrate. Therefore, the pigment has no binder and it will scuff / rub off.
(("""" Alcohol sub acts a very agressive ink solvent. Try using it some time to clean up dried ink. Excessive sub will breakdown the viscosity of the ink causing emulsification. This break down in viscosity is due to the molecular structure of the ink vehicle changing physical properties due to the sub. As the physical properties change they begin to loose their litho properties one being pigmnet binding, not to mention set speed, drying, and rub resistance."""""))))
Without pigment binding you have a form of chalking.
This is an ink tech giving technical assistance and also noting how damaging glycols can be towards ink, effecting their total litho properties!!!!!
So ink techs are you going to sit there and say that glycols can effect the inks in all these ways but have zero effect on ink mileage?
Come on please, how daft do you think we are. Is it because you haven't embraced and changed technologies, that you don't want to agree and be telling your clients that the current ink mileage could be significantly better if the fountain solution was altered along with the ink. Simply due to a financial standpoint. (more mileage = bonus for the printer - negative for the ink manufacturer.
you do not see ink companies who own fountain solution companies (Sun/Rycoline, Flint/Varn, etc) promoting or even suggesting special compatibility.
