Sounds like a hydraulic pressure problem. But first check for loose connections on the foot pedal linkage. If it's not moving properly it may not be fully engaging the hydraulic system. Then, check your hydraulic fluid. May need to be topped off. If not low, could have air in the system and need to bleed it. Might also need to check for the pump's output pressure, a weak pump may not move the fluid enough. Finally, could have malfunctioning valves. A valve that barely moves could be restricting fluid flow and causing something like this. To be honest I would contact a local service person for this. Hydraulic issues in old challenge cutters can be a huge pain to troubleshoot. For the old models, the fluid that filled them from the factory no longer exists, and there's no guarantee an equivalent replacement will work just as well.
