A while ago Pantone hosted a webinar on their spot color printing system. It was very high level so I asked a few questions of Pantone that I thought forum members would have liked answers to.
Pantone answered today as follows...
Hi Gordon,
Please see answers to your questions below.
Is the press a waterless offset press or conventional offset press using fountain solution?
What is your tolerance in the swatch books for deviation from the target?
-See above answer.
(Combined these questions) Is the OBA content of the coated papers the same for the different swatch book systems? Is the OBA content of the uncoated papers the same for the different swatch book systems?
Best regards,
Lucas Hedgecock
Applications Engineering & Technical Support
Pantone Applications SpecialistX-Rite Incorporated
4300 44th Street SE
Grand Rapids, Michigan 49512 USA
Hi Gordon,
- We utilize a specially-modified offset press which is capable of printing 28 individual spot colors in the same pass. We print dry offset, using ink densities which are tested for printability in a conventional wet offset environment.
- We use Delta E 2000.
- We do not publish a set tolerance however using X-Rite solutions that were implemented in our production process of the guides, we are able to control the color as well as track the Delta E values to ensure the Pantone guides stay within specifications. These tools allow us the formulation of ink to achieve results within a tolerance of 1DE2000, with a goal to achieve less than 2DE2000 for all 28 colors on the page as measured on-press. This leads to better overall printed quality with colors and better visually aligned to the 2010 Pantone Master Standards. Our production process allows more tightly controlled, sustainable consistency with every production run and has shown over 90% of colors achieving the on press target in the Pantone Formula Guide Coated (Solid Coated colors). In recent press runs many colors measuring close to a 1.2 DE2000.
-See above answer.
- Yes, we only have one paper stock used for Coated and one stock for Uncoated. Coated: #1grade 100 lb Gloss Text Stock (148 g/m2) Uncoated: Premium Grade 80 lb Text Stock (118 g/m2). The paper was selected as a representation of a highly common industry-used stock weight containing optical brighteners with an OBAs of 8.1 (coated) / 10.7 (uncoated) per ISO/FDIS 15397:2013.
Best regards,
Lucas Hedgecock
4300 44th Street SE
