pitstop pro vs pitstop server
old guy
we currently have 5 users running pitstop pro. i was looking into the advantages of pitstop server and was wondering if the server version replaces the 5 pro versions or works along side them?
It works alongside. All the Preflight configurations and Action Lists that you have in PitStop Pro can be used in PitStop Server, so you are basically automating the processes and freeing up time for your operators only to look at files that fail preflight, and then take the appropriate action in PitStop.
https://www.enfocus.com/en/products/pitstop-server
You might also take a look at PitStop2Switch which is the Switch Core, plus PitStop Server. This gives you extra routing and automation functionality above that of PitStop Server, and also access to the Switch App Store for additional tools. You can also then add extra Switch modules if you wish to automate and integrate further with your existing systems.
https://www.enfocus.com/en/products/pitstop2switch
You can trial all of the above for 30 days. You can send me a PM, or you can contact your local Enfocus reseller.
