Plate size is incorrect PTR16000
ferlli
:rolleyes:From time to time PTR16000 report next error:
The size check program of the alignment function detects that the measured plate size is shorter than expected one.
I use plate p970 agfa
I used to see this on our fuji plates on our PTR from time to time...the plates were in fact a different size. Might only be 1 or 2 mm, but it was enough to throw up the error.
problem size error is gone
We adjust teaching the plate and centering test and the problem is gone:)
