Polar Mohr 66 Error 585
Magnet23
My Polar 66 cutter is giving a message Clamp Not in Upper Position - Acknowledge 585. So my automatic programming doesn't work, I have to manually input next cut. Any ideas?
chock
Hi sir;
Once a cut has been terminated and the knife returned to the upper dead centre a
timer is started (10 seconds) in the course of which the clamp has to recognize
switch B29.
If the return of the clamp is not registered during this waiting time the
above error message is issued.
Check mechanical adjustment of clamp guiding
- Check adjustment of recuperating spring
- Check adjustment of kinematics
- Check clamp travel time
- Check adjustment and functioning of S390 and S309 as well as switching cams
- Check clamp limit switch B29
- Check cabling to switches
Blessing
superchock@yandex.com
sidneykidney
Maybe try turning the 'knife change' knob anti-clockwise (located under the table next to the on-off switch) and then turn it back to clockwise.
chock
Please follow the steps indicated before
Hi sir;
switch B29.
Blessing
Magnet23
Hi sir;
switch B29.
Blessing
Unfortunately I don't know how to do any of this. I would need detailed instructions.
What About Profitability?
Canon
What about Profitability?
Offset yields new advantages
Read All About It
