Hi, I am trying to help out a coworker and don't have much info on offset printing or what specific press is being used so bear with me. They are running a 60" wide offset press and have to adjust the color keys across the press manually. They are having problems with color consistency throughout runs. They are not able to put density/color blocks across the press when they run jobs because they are continuous print jobs and the customer does not want color blocks on their finished product. The way they are setting their densities, etc are as follows:
Make a set of plates with color blocks/density blocks
Adjust ink keys, etc. and run the press to correct densities
unmount the color block/density plates
Mount the plates to run the job and hope the color stays consistent throughout the run.
This is not the most economical way to run jobs and they have no way of checking the color consistency throughout the run, does anyone have any suggestions/ideas on helping this situation or is this process normal for offset?
