We have to print a job for our customer that requires us to print 877 on 12000 sheets two sided sheetwise. They are requesting a dry trap of this color which has some solids and a lot of screen gradients. We then have to print 4 color process on top of this to create the effect they are looking for. They specifically requested this not be run in line. We are using an SM52 5 color with a coater. In order to make this look good we will have to depowder on the SM52 as well. My question can a UV press be set to print this 877 on the first unit and cure the ink so that you can run process on top of it all in one pass? We have to run this sheet through at least 5 times maybe 6 depending on the spray powder.
