Hi Erik,
Good to know you. Do you primarily develop your technology for sheetfed or web fed presses? We will be installing a revolutionary continuous-blanket-contact web offset press this fall in the United States. It keeps perfect corner-to-corner color register since the press never lets go of the paper from one perfecting printing unit to another (no paper stretch). Is your inking system based on something similar to Goss' digital page pack?
I do know about the situation you are referring to when it comes to ductor presses. I do have to take (usually) about 8 times as many measurements to see the variations that occur on the ductor so our calibration point is centered between those variations. Anything that can stabilize the non-repeatability issues related to any press design assists my system in being more accurate. The press you see in the QuickSet video is a ductor press, and even though our ink pre-sets on this press are near ideal, to reach true color can require one pass through the Closed-Loop system (although we do hit true color a good percentage of the time). A system like yours could stabilize the final variables the we deal with.
It may be quite likely that your system for ductor presses combined with our system could provide for the ulitmate accuracy for a ductor press. The more variations eliminated, the better our system works.
(We have some knowledge that would be considered simple, but not obvious. There are other things we have done which are not so simple - elegant maybe, but definitely not simple. Separating out the variablies, and discovering which variable are important (and what type of tolerances you can live with concerning those variables) is what separates success in a production environment vs non-success.)
What does your system cost? Our sister company (Color Impact International) manufactures web offset presses, and we designed the original continuous-blanket-contact press, the basic design the was marketed as the "Quad-Stack" by Web Press Corporation.
Regards,
Steve Surbrook, President
QuickSet Corporation
(425) 793-7770
[email protected]
[email protected]
