Rampage settings
Ed Ensslin
Is anyone out there still using Rampage?
We upgraded 3-4 years ago before Fuji bought Rampage. Everything has been good until last week. We have some type of corruption on the C drive, basically an update keeps running and has filled up the whole disk, not allowing Rampage software to run. Job vol and Ram vol are still fine.
The tech guy I use has some experience with Rampage, but is worried he won't be able to figure out settings once we put in a new C drive and reinstall Rampage.
If anyone has any tips or ideas, they would be appreciated. If anyone knows someone who has an expertise in setting up Rampage and would be willing to work with us on this project, I'd appreciate that contact info.
Thanks!
Ed
I was told by our FUJI guy that once your rampage box goes boom that you are basically screwed. Made a mirror of it and put it on an external just in case we need to have a box built. Unless of course we eventually move to a newer Rip. If your drive is failing I would definitely try to get it backed up though. We had the same problem with Microsoft Auto updates that we couldn't get to stop so we had a local computer nerd write some sort of code to block it from ever happening again.
