The printing company that I work for purchased a Ricoh C901 about four months ago. We had been running an Indigo series 2 press but decided to look for an alternative due to the high cost of the impression count customer charges as well as the fact that these series 2 presses will no longer be supported as of later this year.
The Ricoh has shown both it's strengths and weaknesses and overall, we are pleased with the results. There are things that the Ricoh can do that the Indigo couldn't and vice versa.
One of the main reasons we went with the Ricoh was (supposedly) it's ability to run 14pt and 16pt stock. Many of our existing customers have expressed their interest in heavier stocks for postcards and business cards and our Indigo was unable to print on anything heavier than 12pt. However, what we've come to find with the Ricoh is what our tech is referring to as PTR Shock. As the sheet is traveling through the fuser, vibration is causing a visible band to appear across the sheet, from operator side to service side, and this is caused by it's weight. Apparently, the extra weight makes the sheet unstable enough so that the toner can't adhere to the paper in that certain area, We don't see this in our lighter weight stocks. The tech was in a couple of weeks ago to make some adjustments and some tweaks but to no avail. Anyone ever come across this phenomenon with either a Ricoh or other machine in it's class?
