B bartimina New member Mar 30, 2009 #1 In InDesign, does anyone know how to make cells in tables with rounded corners instead of square? julie
oxburger Well-known member Mar 30, 2009 #2 Not sure you can. You may have to build it manually using picture and text boxes provided it's not too complex......
Lukas Engqvist Well-known member Apr 6, 2009 #3 as ox says, there is no way of automating this yet…Â*you can allways add it as a feature request ;P
S Sticker Printing Active member Oct 28, 2009 #4 Providing you a link I think this will surely help you. indesignsecrets.com/rounded-corner-tables-and-brackets-on-frames.php
R rholigan New member Oct 29, 2009 #5 work around for rounded corners on a table work around for rounded corners on a table I just went through this issue. You can copy and paste the WHOLE table inside a frame with rounded corners. Hope this helps.
oxburger Well-known member Oct 30, 2009 #6 rholigan said: I just went through this issue. You can copy and paste the WHOLE table inside a frame with rounded corners. Hope this helps. Click to expand... I think she wanted to make each individual cell have rounded corners, not just the outer corners of the whole table.
