We are starting a new system and all approved files need to be saved as .pdfs out of .ai and put into the system so CSRs can preview the label.
My question is: a lot of the .ai files can get pretty big and if I save as a .pdf they can sometimes end up pretty large even if I use the compression options when saving. Is there a better way to save smaller sized PDFs out of .ai?
Sometimes if I can't get the file size down I will save the .ai file as an .eps and use Acrobat Distiller and that usually does it. But, seems like a lot more work than it should be to do for hundreds of files.
Thanks in advance!
Thanks in advance!
