Schneider Senator Random Cutting Problem: No response to Cut
KAMOULA
Hello,
Need Help with our paper cutter . When we press the buttons to cut, the machine does not respond, as if the magnetic buttons are locked. It does not have the push buttons, but the magnetic metal type buttons.
This issue is very random: It will stop cutting once or twice every few weeks for long hours, or works fine for a month or two then stops all of the sudden. It will stop cutting for few hours, then all the sudden it will respond.
Our electrician tried to find the problem why the magnetic press buttons are not responding, but since we don't have a wiring diagram, nobody seems able to find the issue.
I attached a Picture of the cutter for you to see.
We had two Schneider senators. One of them had problems like you describe. We spent about three years and thousands of dollars on several visits by the company. They tried switching many different boards, some of which cost nearly $3000 each. Whatever was wrong with the machine was never discovered, but it caused some of the new boards to be damaged also. We finally gave up and sold it for scrap. I recommend you sell it to the first person who will give you one dollar more than scrap value. Don't attempt repair. Don't call the company. Buy another brand.
hi we need help , we are from Chile I had a hard time with no solutions , sometimes you turn on the first mesure is variable ,and the display shows different values , so the values dont match, and the program doesnt run , so we have to change it manual , every technician avoid to work in Senator because the did not know the cutter ( Polar is the most commoun in Chile ) finally we worked on the brake mantainance and following the instruction Manuals code 93 was useful , so the cutter is working ok , some times we have to use that code to reset, We don’t know if that is correct , so I ask your advice , please anyone could help us on this matter ??
