Scitex Dolev 800 V Error
  • Thread starter Thread starter kala
  • Start date Start date
K
kala
Guest
Hi
When i switched on My Dolev 800V iam hearing a beep noise continuosly like interlock alarm in ctp.
I tried changing the cpu board and vga card after that also i got the same alarm sound when i start the machine also.
Kindly suggest how to sort out the issue.
rgds
kala
Hi
rgds
kala
Kala
Do you get any error messages? Can you boot up the Dolev?
Kala
No error message without any error machine comes stand by mode.
Shall i try to expose some job when the alarm sound is keep on continuing? Kindly advice what to do?
rgds
Kala
rgds
Kala
Kala,
I think that the alarm sound must be comming from the CPU board as this has a small speaker on board. There should be a jumper on this board that should be OFF ( not made) for the speaker.
If the Dolev comes to Standby than try and expose a job.
Kala,
Justnow I tried exposing small job it exposed without any error but still iam hearing the beep sound.
If iam not wrong u want me to remove the jumber on the cpu board or what to do??
Can i expose continuosly along with this beep sound. kindly advice
rgds
kala
