Selecting images behind foreground objects?
Gregg
Is there a way, in Pitstop, to select images that are "behind" other objects, similar to command-click in InDesign?
Re: Selecting images behind foreground objects?
I've been using the "Hide Selection" feature (Under the Edit menu, Cmd-Opt-H) to get foreground elements out of the way and then "Show All" (Cmd-Opt-S) once I'm done. Not a very efficient way of doing it if you've got alot to do but it does work in a pinch.
Edit / Layers /send to back, will also do it. Can be a pain tho getting the layers back in proper position.
Don't forget you can toggle to wireframe view as well, that shows all images as outlined boxes only, making it easier to select something beneath it.
Regards,
David.
