Thanks for your valuable comments.
The text is printed on both cold set and heat set web press.
We take the signatures for binding after min. 24 hrs. after printing, and i think if the only moisture regain issue is there then this is enough time to regain moisture,
Again when we print on heat set press then the moisture issue gets valid, but may not be valid for cold set web press.
Apart from all, we did trial and errors for the problem on single knife cutting machine and problem is getting resolved.........but it is not possible for regular practice as we bind the lacks of job.
Thus problem is arising only at the time of online cutting (i.e. 3 knife cutting) on pinning machine, and max. 2.00 mm of short cover is there.
Please pursue some ideas so that this problem could resolve.
Thanks and Regards,
Jayshree
