Signasetter pro - rip delta drivers
olavo
Hello, i bought a used signasetter pro and now i need some printer drivers and/or ppd to my illustrator and coreldraw .
Someone have this? Windows or Mac.
Drivers.
Drivers.
I supose you have a signasetter and a DELTA tech software.
You don specifically need a printer driver.
Using any software, finally save your work as a PDF file.
Corel and Photoshop, Illustrator etc export PDF files directly, so you don need to make PS/EPS files (that need PPD)
Note: depending of the DELTA version you have, you need to make PDF compatible with PDF 1.3 or beter.
I still use PDF version 1.3 with no problems.
The only job is at the design software. before saving the file configure the PDF parameter to, PDF /x3 standard, for example. It work all the time.
So just save jour job as a PDF file.
You have to configure queues at the delta server so can simply drop this files and wait for the film job to finish.
Tha is it...
Miguel Sanchez
[email protected]
