HI,
New question gentlemen.
Do you or have you used a 'soft proofing' solution on press and if so what were your experiences?
J
[SNIP]You can make color critical decisions.[SNIP]
Just a niggling comment. I agree that you can make critical color decisions if you're using the monitor as a proof for massaging images in PShop. However I don't believe that you can make critical color decisions if you're using the monitor at the press as a proof for aligning presswork to proof or making ink key adjustments. This is because of a well established fact: humans do not have color memory. As soon as you look away from the monitor to a press sheet the color you saw on the monitor is lost. This is why press operators cut press sheets through color critical areas and lay the cut sheet over the proof to make the comparison and to evaluate the match. I have seen press operators try to do that with a soft proof, but the emissive nature of the monitor doesn't allow for that kind of check.
In magazine work there is usually no need to try and make such a critical match - it would be impractical anyway. So, for those types of environment soft proofing at press can be very useful - but not for critical color and hence no need for fancy color managed displays - so Apple Cinema is fine. At least in my experience.
best, gordon p
Gordo, I apprecitae your perspective.
Our first-hand experience says otherwise. Good monitors, good software (in our case ICS...in 2006,2007 and 2008) and we have seen this done successfully.
You would be amazed at how many BIG printers have retired hard proofs. Tough to name names here. But this is done every day. Apple displays are nice and pretty but you wont find them in a press room very often. Waaay too bright. Quato, Eizo, NEC are the best in the world.
Jam -
1. Please define "Soft Proofing" in the context of what you are seeking. Is it a monitor proof for content, is it a contract proof for color, etc?
2. Do you have printing presses or do you send your magazines to a printer?
3. Do your editors and color techs believe in this or will they always require a hard proof for color OKs?
4. Do your pressmen (if applicable) belive in this?
5. Are you prepared to make the total press-side investment: Soft proofing system, monitors, racks for (overhead)monitors, viewing booths or lighting for monitors, training for all involved....? It can be a battle.
6. Will editors and content creators adjust to monitor proofs? Will they actually invest in "real" monitors (Eizo, NEC) and not just Apple Cinema displays?
Ian
