We are trying to improve our sheetfed offset printing quality.
I'm trying to figure out if our ink is trapping correctly.
Measuring with a spectrometer/densitometer i can see that the LAB values of the C+M; C+Y; M+Y and C+M+Y are right on the spot with the ISO 12647-2 specifications.
However, according to the spectrometer/densitometer manual (it's a Techkon SpectroDens), the trapping values are wrong. Using the Preucil formula, and according to the manual, for paper class 1 (gloss coated), the trapping values should be C+M>60%; M+Y>72%; C+Y>85%, but i get all the values below these numbers (C+Y for instance goes around 75%). The ISO 12647-2 doesen't specify any reference values for trapping.
So, what i wanted to know is: Should i ignore the trapping values since the LAB values are ok, should i use other reference values for trapping, should i use the values i'm getting as reference (since the lab values are ok with these trapping values)...
I'm no expert in these things, so any help would be very appreciated!
Thank you very much.
