Spiral Punching synthetic paper
SoggyWinter
My team is producing a run of outdoor textbooks books on 161gsm synthetic paper that we are punching for spiral binding. The bottom sheets of each spiral bundle do not punch clean unless we put a couple of pieces of cover paper underneath the stack getting punched. Is there any way to avoid the extra material use like a different punch pattern (we're using 4:1 spiral) or new punch dies that are sharper? thanks.
Are you oiling your dies?
Also I know you say you’d rather not, but you can replace the pins without replacing the whole die..it’s not that expensive. I was quoted a few bucks per pin on my machine.
