Splice Tape on Heat Seal Pouches
WI-Flexo
Looking for advice on splicing tape for Poly-Prop heat sealable pouches. Standard red press splice tape triggers the sensor on the packaging lines for pouches and also does not heat seal. Looking for any recommendations for a better option. Is there a splice tape that will heat seal? Is there a clear tape available, and do you currently splice on the print side or the back side? Ideal scenario would be a clear heat sealable splice tape that runs through the packaging line seamlessly.
Thanks!
