sheetfed and mostly commercial printing, ctp - trendsetter 8003, workflow - printergy, currently we use 175 line screens, stochastic 20 micron
we have not changed just testing right now. not sure exactly why we are testing this but i think its sales driven, we had a job awhile back a new sales person brought in that was previously printed with stochastic and we could not match it.
OK.
Most of the implementation process will be in prepress - hopefully you have good communication with them. The process is briefly and basically:
1) You must have a reliable, effective, stable printing process in place. I.e. print to the numbers and not using the press as a color correction device.
2) Your plate need to be qualified for the dot size you'll be using. You'll be using Staccato which, for a 20 micron screen, uses a highlight dot size equivalent to a 1.5% dot at 150 lpi with a midtone dot size of 24 microns. It's equivalent to a 385 lpi regular AM screen.
3) You need to speak with your ink vendor to confirm that your current ink set is suitable for such a high frequency screen (pigment load, viscosity, tack, etc.)
4) Prepress will build curves which will be applied to the plates during imaging to compensate for the increased dot gain caused by the use of small dots. To do that they should run a 175 lpi test using your current setup which will become the target for your Staccato presswork. They will than run the test form using uncalibrated plates with Staccato screening. From those two press runs they will have the info needed to build plate curves.
5) They should then go on press with the same test form to confirm their curves.
6) Prepress may update their proofing to reflect the slightly larger color gamut of Staccato.
Some things to note:
FM screens are more stable on press than a 175 lpi AM screen. Color can be moved - but not as fast or in the same tone areas as a 175 lpi.
The gamut/color range is larger - primarily in the quarter and mid tones. That means that one an two color screen tint builds will look different.
You will use slightly less water because the ink film thickness will be slightly lower.
Printers who are successful with this type of screening are so because they are committed to it and use it 100% and only use 175 lpi as the exception.
You might find some of my blog postings helpful. These in particular:
http://qualityinprint.blogspot.com/2009/02/golden-reference-part-one.html
http://qualityinprint.blogspot.com/2009/02/golden-reference-part-2.html
http://qualityinprint.blogspot.com/2008/12/2nd-order-fm-screen.html
Or rummage around my print blog here:
Quality In Print
hope this helps, gordo
