Standard Creates A Complete Feeding & Finishing Experience @ GrephExpo
prwhite
Administrator
Staff member
Standard Finishing Systems (Booth 831) will occupy one of the largest spaces on the show floor at Graph Expo and will pack equipment into every square foot creating a complete feeding and finishing experience. Standard’s showcase includes die-cutting, perfect binding, trimming, creasing, folding, saddlestitching, inspection systems, and roll-fed print solutions, as well as the premiere appearance of 2 new products.
A comprehensive range of finished products will be produced on-site, highlighting the short-run capabilities of individual systems and complete end-to-end workflows. The full gamut of production finishing will be displayed, including:
  • Book blocks coming off one system–perfect bound and trimmed near-line to produce finished books;
  • Pre-printed rolls turned into saddle stitched booklets with variable perforations, in a single pass;
  • Samples creased on one machine and folded near-line on another, creating calendars, greeting cards and a variety of other folded output;
  • B2 printed sheets will be processed into full-bleed cut sheets with intelligent accumulation and stacking to create book blocks.
Standard will introduce and demonstrate several new products:
  • New Horizon SmartSlitter, an all-in-one smart sheet processing system that can slit, gutter cut, edge trim, cross-cut, perforate, and crease in one pass;
  • New Hunkeler DP8 Dynamic Perforating and Punching module–part of a Roll-to-Booklet Solution–processing pre-printed rolls into finished booklets with dynamic perforations throughout, at speeds up to 600 fpm;
  • The Hunkeler UW6 Unwinder and CS6-I Cutter in-line to the Horizon StitchLiner 6000 Digital Saddlestitcher, and will be equipped with the Hunkeler WI6 Web Inspection System for full quality and integrity checking and tracking to the finished document;
  • The Standard Horizon SmartStacker will be converting B2-size sheets (20”x29”) into as many as 28 full-bleed cut sheets with intelligent accumulation and stacking. The SmartStacker can be used in-line with the HP Indigo 10000 Digital Press, or offline;
  • The “VIVA” suite of vision-based inspection systems – custom-designed for document integrity, quality control and verification in production environments.
