Suprasetter A74 motor problem
totitotek
Hello everyone,
We are experiencing an issue with our Suprasetter A74 (2007).
It started about a year ago with occasional errors 07951 (Motor end stage detected an error and is locked) at the end of plate exposure and 07956 (No index pulse was found …) during machine startup. Over time, these issues have become more frequent. We are now also encountering errors 07403 (An error occurred when conveying a plate …) and 07412 (An error occurred when conveying a plate). These errors are caused by the drum not rotating. Error 07951 now also occurs during the exposure process at various stages.
Interestingly, if I expose only 1 or 2 plates at a time, wait a few minutes, and then expose 1 or 2 more plates, there is a higher chance of no errors compared to exposing all plates at once.
Our technician suggests that the motor might be faulty, but I am hesitant to replace the motor if the issue might be something else.
I would appreciate any advice.
Thank you.
Hi sir:
Please review the sensors between input and output , look for faulty connectors, or corroded, or dirty, and clean very well.
Of course look for the regulated power supply according with the wiring diagrams, if there are in Tolerance.
note: I have all tech documentation for Heidelberg Suprasetter A 74 and others.
Blessing
[email protected]
Managua, Nicaragua Central America
Cell+ WhatsApp:+ 505 8861 1441
Most likely it's the motor or the belt. Belt could be worn out or slipping. Adjust the belt tension. Then replace the belt or the expensive motor.
Hello everyone,
Thank you.
It is very interesting. Pls send me log-file from GUI for 10-12 days. I am not sure but it seems to me you have a problem of encoder or belt tension or its condition
Hi sir :
Did you fix it ??
I have service manual for Heidelberg Suprasetter CTP, and all information for that machines.
Blessing.
[email protected]
Managua, Nicaragua, Central America
Cell- WhatsApp: + 505 8861 1441
