We're entering the 2nd decade of the 21st century and there's still room for improvement. Maybe you've got some ideas for the vendors who frequent this forum?
Here's a few technologies I'd like to see developed:
1) A desktop inkjet printer that sells for under $200 that:
a) Has a straight through paper path option so that I can print on heavy weight paper
b) Can print a page of any length
c) Can print black only - even when the other ink cartridges are empty
d) Can clean just the nozzle that's blocked (rather than waste ink cleaning the nozzles that aren't blocked)
e) Can use profiles other than sRGB (not critical but nice option) so that it can be used for basic color proofing
2) Inkjet proofers that don't dump the proofs on the floor.
3) A press manufacturer evaluate and test Erik Nikkanen's ITB.
4) An alternative to FTP. Creo had developed a product called "Tokens" which was great but never marketed.
5) A desktop file creation overseer/manager. I.e. Designers would set the target for a job (e.g. GRACoL 7) and the software would organize color management and application parameters to constrain my design so that it conforms to the needs of that destination. The overseer/manager could also accept custom parameters that might be shop specific. Perhaps it could be scaled so that its tolerances would be widest with no destination targeted and then it would monitor and constrain when a target is specified. The intent is to eliminate preflighting a job to find errors and correct them after file creation.
6) Press side scanners that scan the entire sheet and can compare the press sheet to the proof in relation to the data on the plate. The intent is to eliminate the color bar and to close the loop between the file, prepress, and the pressroom.
I'm sure you folks who are still in the trenches have many more ideas for vendors to explore.
best, gordon p
best, gordon p
