Technotrans Dampening System Temp.
cheetoh
I run a Heidelberg 6 Color 102CD, I am Curious about the Temperature settings on this unit. Is there a Standard temperature that should be ran to the water running through the Rollers and the Temp. of the Water in The Fountain solution tank? What is a good starting point for each?
13 C is a good average temp for the fountain solution. Back in the olden days when the guys ran alcohol you ran the tank colder to slow down evaporation, plus it kept the beer colder on afternoon shift??
We run our roller chill unit at @ 21 degrees Celsius = 72 far. The water tank we also keep at @ 12 degrees. Same with the beers!:D
