erik
this may look silly.you are all the time talking about positive inkfeed and i understand and agree,but how about the waterfeed? if the water feed varies is it not going to affect the emulsification and thereby affect the amount of ink going to plate/blanket/paper?
As someone who has worked with a fully closed loop inline density measurement scheme for almost 10 years, There are of course many variations, I could easily create a printed sheet with the same densities, but both looking completely different. As long as offset lithographic printing exists I don't believe we will ever remove all of the variables, all we can do is invent better ways of detecting and controlling them.
Ironically these systems designed to simplify the printing process get the best results in the hands of the best printers.
the speed and efficiency of the make ready process on a sheetfed press i feel has more to do with accurate inking. any pressman worth his salt should be able to get a decent handle on dampening variations.
but if you eric can wrap yourself around this one i think it could provide a little insight as to some of mysteries we face.
lets go back for a minute to the pre cip3 and cip4 days.
there were times when my initial settings on all of the plates we pretty darn accurate. as a matter of fact i usually trust them more than i do current cip data. well now try to remember how every now and again youd get that mystery job that would require really large fountain settings in a zone with zero or close to zero ink takeoff.
ever wonder where all that ink was going???? .
[SNIP]every now and again youd get that mystery job that would require really large fountain settings in a zone with zero or close to zero ink takeoff.
ever wonder where all that ink was going???? [SNIP]
5 times the amount of ink i originally set up the fountain for just to print a damn color bar up to density.
perhaps someone here can find all that missing ink cuz i know ive looked for it and not been able to figure it out. just an example of a part of the inking process that needs to at least be given some thought.
I'm probably completely wrong on this (be gentle Erik) - I've seen the same thing happen usually with Annual Reports which often have very thin lines of ink - often a PMS ink - in the financial section.
I used to think that, because the lines were so thin that they would be over powered by the fountain solution. So the fountain solution would wash out the ink on those fine lines and you wouldn't get the density you thought you should based on the amount of ink you were pouring into the press.
However, if you put a large enough ink take off bar inline with those thin lines their density would increase to what you would have expected.
So, and this is complete speculation, I'm guessing that there is an ink push-pull relationship. You can push ink into the system, however, it also has to be pulled onto the sheet. The thin lines just didn't have a large enough area to pull the ink off the blanket. However, by putting an inline take-off bar on the sheet that increased the "ink pull" area in that zone and allowed to ink to flow which restored density to the thin lines.
gordon p
i wanted to test Erik´s ITB on a komori 40" but before that, i needed to prove to my boss that i was right and that Erik was right so i started on small presses, and started studying the way ink is transfered and i noticed that the problem we have is that we cant really control the volume of control needed for the press to run without variation in density, of course the ink going in is the ink that needs to go out and the storage needs to be constant no matter what, better yet we need to maintain a "constant flow" of ink during a run but this so called constant flow varies depending the job, imagine a 10 sq in image and a 20 sq in image, both at the same speed, you will then need a higher mass flow to provide the same results, so if you have this limitation that the presses do have "constant mass flow" you then will have to reduce the speed on the 20" to have the same results as in the 10", so i believe that the device that should be on the press doesn't need to be on the blade, but on the nearest point of the plate, then the plate will take what it needs, but, i do agree in something very clearly with Erik and that is that the oscillator near the ductor has to go.
I believe that the whole problem is because we need constant speed, (speed during a run) and the plate is the one that should demand the amount of ink needed for a job, so speed in the fountain rollers need to be constant to, is the plate picks only the amount of ink needed for the job and you have a volume of control so the plate can do this then you will solve the problem, its al about fluid dynamics and van der wals interaction nothing more than that, i haven't been able to make more investigations on the subject because its kind of busy in here but as soon as i make something ill post the results.
Hello fellow Lithographers, learners also Mr. E. Nikkanen,
Salient Points -
#2 The fundamental principle of Ink Transfer is the "Walker & Fetsko" equation, proposed 50 years ago.
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
