I told them.
The ph, conductivity and temperature are all dependent on which fountain solution supplier/product/type/1 step or 2 step, etc. The temperature of the fount (tank/pans) is dependent upon the press as well as the ambient temp./humidity of the pressroom. If a press operates without chilled vibrators, than the temperature of the fount may and probably will be different versus a press with improved temperature controls.
Remedies:
A) Get a reliable fountain solution provider who will put boots on ground inside your pressroom. Make sure he monitors the complete press via an audit, infeed to delivery. He should stay on your floor a minimum of 2 days, and gentlemen, that is just for one press. Purchase the etch/sub or fountain solution from a company that only manufactures, technical services and provides prompt delivery. DO NOT BUY FROM ANY INK PEOPLE, DEALER or OTHER SOURCE THAT IS OFFERING YOU TRIPLE MARTINI LUNCH. Stay away from any BUNDLED DEALS, or PIE IN THE SKY SCEMES that will require you to BUY from one company. Get yourself an individual TECHNICAL REP for every consumable product on your presses. INK TECH, FOUNTAIN SOLUTION TECH, BLANKET TECH, PLATE TECH, PRE-PRESS TECH., ROLLER TECH and PAPER TECH (this one is the hardest of all to find). Be cautious! Look for the signs of an unqualified technician. Here are some clues: WEARING A TIE, TOTING DONUTS, LONG SLEEVED SHIRTS, SMELLING OF COLOGNE, and TAKING LONGER THAN 1/2 HOUR for LUNCH. If the FAKE TECH is fake you may find him LEAVING YOUR FLOOR at LUNCH and going out with a non-printer TIE GUY from the OFFICE. If you detect any of these, THROW 'EM OUT, They are of NO HELP to your productivity or operational well being. Make sure "the boss" gets thi, so he will not be FOOLED also.
B) Keep in close contact with your press manufacturer. They will know exactly the proper running temperatures throughout your press based on which make and model you have.
That does it.
Happy Lithographing!
D Ink Man
Remedies:
That does it.
D Ink Man
