CTP plate geometry
CTP plate geometry
While the overall dimensions of the plate are critical to the proper operation of the CTP hardware the tolerances of the plate IMAGE are much tighter and critical to the printed job.
The physical plate can be measured relatively easily with a caliper, or for the accuracies quoted, a good quality ruler will suffice. The image, on the other hand has no convenient physical edge to hook the caliper over, and if high quality commercial tolerances are to be held, much smaller dimensions are being dealt with. For a 150 line/inch screen, a half row of dots is about 0.085 millimeters or 85 microns. Better printing at 175 lines per inch leaves only 72 microns. These register errors are beyond what can easily be measured with the unaided eye.
Upon initial installation many CTP engines require geometric calibration; is a 750mm horizontal line equal to a 750mm vertical line? Is the left side equal in size to the right side? The top to the bottom? If not adequately addressed, these small geometric errors will plague the pressman in numerous ways.
A non-contact, video-enhanced measuring system makes measurements of this type easier, faster, and more accurate than any amount of squinting through a magnifier and a glass scale. Once a video subsystem is employed image capture and color-separation contrast enhancement is readily accomplished.
The Beta Video Ruler offers all of these features in sizes up to 2000mm (80 inches). More convenient units of 24, 30, and 40 inches are also available.
Details can be seen here:
video ruler
Contact Beta or your local dealer for information or to schedule an in-plant evaluation.
Best regards,
Larry Goldberg
Technical Director
Beta Industries
[email protected]
Color Densitometers, CTP Calibration Systems for Print Quality
