Alois, i don´t understant this pdf sorry, I want to Know if you or another people appied the torque that recommended the manufacturer of the press. Do you think 98N is a lot of torque??
Thanks.
(Determine settings for each type used)
Each blanket is a little different depending on the backing.
I would put blanket on press with a minimum setting to get started. (Document)
Run press on pressure for 50 impressions.
Shut press down and inspect sheet for register and printing defects caused by having a slight bubble from possible excessive material being stretched to the blanket gap.
Go to printing unit inspect blanket for lose fit and a slight bubble or soft spot at the gap. Information at this point should be pushing you to tighten the blanket some more.
Tighten blanket in a 10% increment. (30 lbs would be a three pound increase to the wrench.) Document.....
Inspect blanket and see if soft spot / bubble has disappeared. If it has, run another 50 sheets and check again.
Keep doing this until blanket and printing are telling you that you are set correctly. (No soft spot at the gap and no register issues at the tail.
This is the setting point and you have personally determined what the set point should be.
Blankets can and have been over-torqued in most situations that I have seen. Operators do not seem to care unless management is standing there watching and then it will be found that the torque wrench is set wrong or broken. I had to audit to keep in compliance. You as well can see issues when the blanket is tightened past the click on the wrench. I have seen blankets only getting about half their life due to being pulled so tight that the backing was stretched flat and could not take a hit.
Just some thoughts...
Tk
