Transparency Blending Color space
Cewa
We are using Harlequin RIP ver9.0.
We are getting some PDFs (ver 1.7) with Transparence Blending space as Devics RGB (although all the images and vectors are CMYK)
When we RIP this PDF the dot values of the CMYK images and vectors change.
I was told that there is a setting in the RIP that can take care of this issue.
I am unable to identify this setting. Anybody aware if this setting?
Thanks in advance
Cewa
Hi Stephen
Thanks for the idea.
I have also tried flattening in Acrobat and it works. But I feel doing it in the RIP is more efficient as we need to deal with a lot of PDF daily.
Regards
Cewa
Agreed, however I can’t help with the RIP.
This is where PitStop Server comes in, hot folder automation, the output from the PitStop Server hotfolder can be the input folder to your RIP.
Hi Stephen
Regards
Cewa
Hi Cewa,
Just make sure that you're using the correct ICC profile during the conversion to get the optimal results. Ideally you'll have different workflows based on different substrates and ICC profiles that will feed your RIP/ reside in your RIP.
Greg
Thanks in advance
Cewa
​Can I ask what the source application was for those PDF files?
