Upgrading to a Canon V700
RoganJosh
Hi folks, I'm close to pushing the buy button on the Imagepress v700 - Previously we had an Imagerunner Advance 7065i - for the last 10 years. I can't say it was a great machine - registration - awful, colour - great, then awful after a few sheets, Paper handling - not bad then awful. The one shining light was the servicing - but the techs would only fix the issue that you complain about - not the 5 other things that were wrong with the machine.
Anyway - the business needs a digital press to keep going and we are on fairly good terms with Canon.
I'm wondering whether anyone here knows about the Imagepress V700 800 900 range - am I making the right decision going down this path, or will it just be like getting the Imagerunner Advance 7065i that I purchased 10 years ago.
Thanks in advance.
bcr
so you had a machine which you weren't happy with, and you weren't satisfied with the level of service where they were leaving multiple problems open and unresolved, but you think you are on good terms with Canon?
you might want to rethink that and get competing offers from the other major manufacturers, and then go and do some high volume stress tests on the machines proposed using your own substrates. then ask them for local clients of theirs and do your own research on their level and quality of service.
bcr
There are definitely options and you owe it to yourself to shop around, no reason to settle for a machine / service you aren’t totally happy with.
you also have no idea about whether you are getting value for money if you don't compare and negotiate based on competing offers.
your current supplier knows what your current deal is. so they have little incentive to offer you a sharper deal unless you push them - you have to keep them honest.
for example - before we set up our repro, our previous supplier offered us a single KM 3070 (not even the press version), and two small office bizhubs for about the same price as our previous deal, including some fixed minimum click charges.
eventually i was able to get two highly specced Ricoh C5310's, three fast colour office copiers, and more than 10 BW small desk MFC's for about the same monthly cost, but with no minimum clicks included (our preference).
In the end I'd say we got a WAY better deal due to putting the time and effort in to shop around and negotiate.
you have to keep your suppliers honest :)
RoganJosh
BCR - you gave me serious food for thought. We are a small printing company, 2nd generation family run our first digital "Press" was an OKI - which gave us a taste of what was possible - the consumables cost killed that machine so we moved to a Xerox DC3535 - another terrible mistake driven by the charisma of greedy salesman. It never did what we needed and the Engineers had to set up camp outside our printshop to keep us going. The Canon has been much better relative to our previous 2 machines and although we have had problems, we've worked through them. As we are such a small company we don't buy machines regularly enough to throw our weight around.
After reading your comment, I got in touch with Ricoh this morning - the salesman was very wary of us - saying he couldn't compete on click charges and would rather sell us consumables as required and use a click for maintenance. He pretty much threw the towel in within a 5 minute call.
Your second post about keeping suppliers honest is also extremely thought provoking. I'd like to say we have tried to do that throughout our business suppliers - but recently found out that our paper merchant is been putting his arm in on pricing - we have alerted him to this by cancelling long term orders and using an alternative supplier in the last few weeks. But again - our size is putting us at a disadvantage - we simply don't spend enough on materials to even register on a large supplier's barometer.
As far as I know there are no installations of an Imagepress v700 in my country (Northern Ireland) - but I guess the next step is to push Canon into proving the machine before I hit the buy button.
Namelessentity - you have a simple reply - the registration sucks on v700,800 and 900 - this is entirely possible, but can you tell me what experience do you have of these machines?
kslight
The deal you can get will certainly vary by location and by volume. Even if your current vendor ultimately provides the best deal to you, you wouldn’t know unless you shop around. And it’s likely that if you let them know you are shopping around, they will sharpen their pencil for you. Just business. Previous owner at my work didn’t negotiate the printer contracts, just accepted whatever her friend (a sales rep) put in front of her. When I saw that numbers - having identical proposals in hand from my previous job - we got screwed by thousands of dollars per month, and had a poorly running machine with an apathetic and delinquent service department. I fired them the moment our lease was up. And we only have a single printer also, but I expect are running higher volume, we are able to negotiate very fairly.
namelessentity
We are a Canon shop. We have an Imagepress 750, a 10,000 and a Varioprint 6320. We were sold a 750 as a proofing machine and a lightweight backup for emergencies.
It does a poor job of staying in register when you calibrate media. It also does a poor job of holding that registration throughout a run. We've definitely had to re-run jobs because halfway through the job they're several mm off.
We only got the basic model with the bypass tray and the basic 3 drawers. Our salesperson told me if you buy the POD deck the registration is more reliable, so if you do go with Canon I would get one with a POD Deck or the POD deck lite. The bypass only holds around 15 sheets of cardstock, and it does an adjustment every single time you reload stock. so long runs on heavy stock are a chore that requires you to to be tethered to the printer the entire run.
It also jams quite a bit on envelopes, which was another thing we were sold on that was a disappointment.
RoganJosh
The V700-900 are a new range of Imagepress machines - it sounds like you have an older Canon (750) - is this an Imagerunner Advance or similar? If so - yes, I agree the jobs would go out of register quite quickly, even with the POD deck - which we have. Also colour drifts in and out throughout a run - giving huge variation with register and quality on even small runs. But I'm lead to believe that the V700 has a corner register system which should ensure tighter front to back register - even allowing 350gsm to duplex with less than 1mm misregister. I had thought it came with a built in spectrophotometer to ensure colour consistency - but this is an extra for the v700 and only standard on the v900.
@pippip - I'd estimate 50k per month for a mixture of colour and black and white - with about 150k being run on Litho per month. We hope to move more litho onto digital - but confidence is low in the last week - with our landlord increasing rent by 20% from April.
pippip
If that's 50k per month SRA3, I'd exaggerate that to 75k+. I'd say you'll naturally migrate certain litho jobs over in time.
We had a DC3535, our first digital press, can't say I remember it being too bad but at the time going digital it just seemed amazing and we knew no better.
I'm surprised Ricoh didn't seem interested, maybe just an off day for the salesman. First I've heard of maintenance only click charge in Ireland. I'd still push them for a quote anyway on a proper all in click charge, just to compare.
I'm in Dublin but oddly enough our Xerox sales rep on the V80 we have is based in Northern Ireland, Emmanuel Duffy. Nice chap and always went out of his way to help with anything.
Coming up on end of 1st quarter so may get better interest, I always find end of year is best for deals.
namelessentity
The 750 is an Imagepress. If the new V models have corner registration then it should solve all of my complaints with registration. That's what our 10000 uses and it's fantastic.
TJPrinter
On paper the new V series sounds like a great little machine. Make sure you run some serious tests on one of the new V machines if that’s what you’re looking for
I’d make sure that if the corner registration mark is required for decent front/back registration that it will not get in the way of a similar registration mark that something like a Duplo would use for slitting/scoring.
My biggest problem with the Canon service that I had for the C810 was that if the registration was listed at 1mm in the CED then the techs wouldn’t try get it any closer and that was 1mm on each side for sheet to sheet, so front to back could go off as far as 2mm and that was okay with them. My old Xerox 700 had better registration than that.
Koenig & Bauer Video
Canon 2022
The Video You Really
Need To Watch
View The Video
