I am having color problems with my Versant 4100. Up until 4 months ago my 4100 printed great. Since then there seems to be a color shift. It seems like it is printing with too much magenta. Blues are shifting into the purples. The blue sky in photos has too much pink (magenta) in them. I have had technicians in 3 times to try and fix with no solution. I have had a software specialist look at the fiery with still no solution. I am at the point where I can not trust the color to be accurate.
I have calibrated the stock, I have cleaned the toners, I have cleaned the fuser, etc. with no luck. I can apply a curve to lessen the magenta cast but that has an effect on all the colors. In some instances it makes photos appear more yellow than they should.
Is this a wide spread problem with the 4100 or is this isolated to my press? Has anyone had this issue and if so do you have a solution?
Thank you for any advice.
