Well, I do understand that it's meant to be a tool to help you reach a valid G7 state rather than a check sheet or spectro-photometer calibration tool.
The thing is I'm trying to work with several different printers. In the mix are several different digital color presses, a DI, several different 4-color offset presses, different papers, etc... All the things that G7 is supposed to help you deal with. Everybody claims that they are calibrated, that they are doing it right, but not a single process matches any other, and none of them match my soft proof.
So, while there's obviously a lot of work to do there, it sure seems like it would be helpful to start from "Here's what it ought to look like".
What's frustrating is that so many printers don't even seem to know that. I know two large offset printers that didn't even linearize their presses, I'm not sure anyone even understood the concept that you'd have a press profile or reference conditions. They've just got a pressman yanking ink levels back and forth on a per job basis until it "looks right". I really don't understand this industry sometimes.
Basically from what I think I understand about the G7 process. The goal is to develop a standard set of reference conditions for a press, paper and screening so that when you run to a set of standard densities you can know that several defined CMYK values will produce a neutral gray.
If this is true, then you can reliably expect the overall hue and value of the image ripped through that same process to be very consistent, even on different presses. An individual spot color may not match perfectly, but overall image "A" should look very similar to image "B"; the color balance should be the same, and contrast should end up the same.
For digital presses there doesn't seem to be an effective way to apply the curve-adjustment algorithms (please correct me if I'm wrong). But I'm not sure it matters anyway, because you should be able to use the Gracol Coated profile and the color management of the digital press should do a pretty effective job, producing --again-- not necessarily an exact match but a result that should generally satisfy most customers.
So, I'm looking at trying to develop quality control tools. I already know I'm going to get he-said/she-said push back if I try to compare one printer's output to another. It seems to me like the only way I'm ever going to get a good start is to be able to come in and say "Look. here's an example of a working implementation. This is the standard. Now we're going to iterate through this process until we can achieve something like this, and you're going to make sure that you can keep producing this going forwards."
OK, now you've got me worried that I've got some really basic misconceptions, Gordo.
Isn't press linearization pretty much step one for any standards process? I want to be able to say 30% and get 30%, right? That seems to be fundamental.
Fact is that what the entire G7 process began as an attempt to duplicate in offset lithography the linearization process that's already included somewhere in the routine of every RIP-driven digital printing device.
Once you're creating dots digitally it's to all that difficult of a process to establish a routine to do some sort of calibration/linearization (the terms loosely used somewhat overlap.)
Of course it's much harder to do on a litho press because of all the variably factors involved, and up until digital plate making, it was pretty much impossible.
And understand that color management on a digital device is something that has to be done. It doesn't come in the box from the factory. If you want to attempt to hit a Gracol proofing standard with a digital device, first you have to calibrate and characterize the device,…
Not exactly. One might linearize the platesetter to ensure correct exposure, et cetera. I actually quit linearizing platesetters long ago. I get better results with the natural response of the plates. You must linearize an inkjet proofer before profiling. But, you don't 'linearize' a press.
It sounds like you're operating from the position that dot gain is a bad thing. It's neither good, nor bad, it just is. You can set up your platesetter so that a 30% in the file will yield 30% on press. I've done it, and it looks like crap. Trust me, we like dot gain. Printing without dot gain looks hollow and sharp. I've never ended up using linear plates. Some level of adjustment has always been applied to pull the plate out of linearity.
If you look at the ISO 12647-2 TVI curves and/or the G7/GRACoL NPDC, none of them are 'linear'. They all exhibit non-linear responses. What you're attempting to do is get your presses' dot gain responses to align with the dot gain of the standard you want to match.
In linearizing my goal isn't to directly make the output look a certain way, but rather to be able to control what that output should be. [SNIP] But if I'm going to emulate any of those characteristics on my press, then step one is understanding the actual characteristics of my press, right?
Sure I could just leave it alone and say "Well, I'm running an offset press, that should be kinda like the theoretical offset press used for SWOP standards. I should be OK, then." And yeah that would kind of work, but if I want to do better than "kind of" I've got to actually understand the true response of my press so I can compensate for the differences between it and the theoretical press.
Gentlemen,
Tone Reproduction
A PDF - I hope you will find of interest and value - BUT
It might muddy the water - !
Regards, Alois
[SNIP]
I'm kind of thinking that everybody here is basically saying the same, thing, and that most of the smoke is a matter of terminology. I'm suspecting that the term "linearization" maybe has some meanings I'm not aware of.
I do prefer to think of things that way, though. It seems easier to me to think of a the press as a linear device, and consider the delta between linear and the theoretical dot-gain curves for a profile, rather than to try to think of two separate curves and the deltas between them. If there's a problem with that, I don't understand it.
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
