That study contains so many errors and is so poorly conducted that it should basically be ignored.
Please see my edit to the original post.that's nice!
Gordo,
Thank you for the Clarification regarding the "Dissertation from Clemson Uni.
Regards, Alois
From my experience as an operator, I prefer FM screening. It carries (a lot) more detail in halftone and process images so your oh so popular full color printing these days has never looked better. There’s also no chance of Moire or Rosette pattern, so in those regards, there’s nothing better.
But for printing screened tints of solids, AM is superior because it lays down smoother and shows no grain.
And far as AM dot patterns go, I also like Euclidean better but Elliptical is very similar. Look at your shadows, midtones, and highlights for reference.
Hybrid screening was developed to merge AM and FM screening together and in doing so tries to produce the best of both worlds. I’ve not actually printed too much of that in practice, so I can’t comment too much about it. But I have heard that just like other types of screening, it has its own issues as well.
I don’t think that the Hybrid screening I was referring to that’s in use in offset today, has anything to do with Flexo. As far as I know it was specifically developed with offset in mind, and it actually does combine some elements of FM screening with AM screening (among others) to essentially provide the best of both. I can’t can’t comment on its performance, though, because I’ve not worked with it before. Here’s one brand that I’m aware of:
Auraia Digitally Modulated Screening DMS - Hamillroad Software Limited
Auraia DMS dramatically enhances quality, stability, and gamut, while delivering ink savings over conventional screening for offset / litho printing.www.hamillroad.com
Hi Magnus,I have tried Round, Square, Euclidean in AM screening and printed a few jobs using FM, but have settled on Elliptical with 7.5° shifted angles as our standard.
Also had good results with FM screening for C,M & Y and AM on the black, it appears to give a sharper appearance.
I haven't used that technique since the Brisque days, and of course the FM screening has evolved since then.
@gordoAh. I don’t think I’d class DM screening as a hybrid. Most people would associate hybrid screening with Agfa’s XM. There are similar screening technologies from other vendors. Those were originally developed for flexo and were subsequently applied to offset for the same reason.
@gordo
Could you please share your idea about this screening DM? what is its disadvantage?
Do we need good consumables, good blankets... to print it on an offset machine?
Thanks in advance!
For more detail:
AM dots: AM Screening Halftone Dot Shapes
FM dots: AM Screening Halftone Dot Shapes
XM: Hybrid AM Screening/XM Screening
DeltaE, none of the books we printed using this method had any flat tints, we always found FM to be too grainy for those jobs, we would pick & choose which jobs to print this way, most were books with blocks of mainly black text with photographs, so i couldn't really comment on the stability of 4 colour neutral greys or other flat tints.Hi Magnus,
It sounds interesting with combination FM-C M Y and AM-K. Beside the better appearance, how do you think about the stability of color, especially gray tone (ex: CMYK = 50 40 40 15)
