I have two questions for you. The image that's causing the questions is attached.
1. I have a CMYK image that has an embedded profile: U.S. Web Coated (SWOP) v2
If I open it in PShop (CS3) with "Use the embedded profile (instead of the working space)" the image opens up and every thing is correct.
But, ff I open it with "Convert document's colors the working space" the image opens up and C, M, Y are the same - but the K channel appears to have been reseparated since it now has C, M, Y tones and the K has changed.
I thought that CMYK values weren't supposed to change (and they didn't for CMY) so, what's going on?
2. What would cause only the 100% K patch in this graphic to change to 4/C in a Rampage workflow?
thx, gordo
PS This question is also posted in the Color Management area.
thx, gordo
