StreamImports
I have artwork that has logo but I decided that I want to have circle surround that logo but revision of artwork is not an option at this time and I need to get it printed fast. The paper is black coated matte one and what I want to do is to use 2 methods in total to have golden debossed effect:
1. Debossed gold foil stamping for logo
2. Debossed hot stamping for circle that surrounds logo
The reason that circle will use different method is because it is placed on the edge of paper which I assumed will be compex to do with foil but I may be wrong. See attached example below where I tried illustrating it.
Questions:
1. Is debossed foil hot stamping different than debossed hot stamping? I read that this method can use either foil or ink.
2. Would using both methods cause inconsistency in look and golden color for both logo and circle?
3. Should I worry about debossed foil hot stamping be more complex when doing this on edges of a circle?
Thank you
Questions:
Thank you
