I've tried to find that fault code using Xerox's own instructions, but it doesn't come up with anything. I guess this is one instance in which you'll have to call tech support. It's usually pretty painless. The person answering the phone will usually be able to tell from the fault code if you need a visit or if it's something you can fix.
I do believe code starting with 12 have something to do with the finisher.
