Xerox CP1000 synthetic paper Robuskin
polf
Robuskin XTP 200 gsm synthetic paper won't print on our Xerox cp1000. After printing 1 or 2 sheets the paper stays in the paper tray. In the beginning there was a lot of static electricity, but as we fed it through an offset press, this is resolved. It is acclimatising for about 4 days, this doesn't help. Xerox technicians can't help us. Can somebody give some tips concerning synthetic paper transport?
Synthetic paper WILL ALWAYS BRICK FROM STATIC there is no help, it is what it is. It's even more fun when you are finishing it and get your begonias zapped when trying to jog it on the cutter bed!
I use Xerox poly with no issue on our 800. Try going into the advanced paper settings, there is a support table for both multi-feed and paper jam (no feed). You can also tweak the settings and create your own. Reference the System Admin manual.
We did the test on a MGI and this worked well. Thanks to our partner with this MGI we can use those 4000 sheets.
