Xerox plockmatick
Kyle Arn
Hello I have a Xerox Plockmatick attached to a Xerox Color Press 1000. I used to be able to have the 1000 set to feed directly into the plockmatick in the Fiery I would select bypass tray and it would feed in but for some reason The bypass tray has been grayed out. All the chords are connected just cannot select it as an option. Anyone have any ideas on what to do? Thanks in Advance
Don't know about the Xerox, but with a Ricoh we had to power down the machine, then power up the Plock and roll in place, then power up the machine again. The option was then available.
Thanks for your reply turns out the answer was in my Fiery Settings had to turn the DFA on to enable the option.
