not the holy grail!!!
Hi Lee,
I struggled with 2in1 for around 4 months a while ago, it is alcohol based, although not IPA but 80% NPA. Worked ok on the Octoman web but hey, if you can’t get a fount to work on a web, you are in the wrong job! We had a Speedmaster 102 6colour, we used a fount dosed at 2.5% and IPA dosed at 4%-6%, water levels were quite low at between 15%-18% throughout the day. 2in1 was supposed to reduce our water levels but to be honest, at the levels we ran at, they were never going to be much less than we already ran at. Principle of lithography does require SOME water! We had a problem getting consistent dosage of 2in1 through the Technotrans Alcosmart unit to begin with, the rep from Algraphic supplied a conversion chart that should have fixed the problem but dosage was still erratic and not that accurate. I looked at the website as you suggested for bmmprint (who they?) and I would say that if the recalibration instructions are correct, there would be no need for a correction chart! Any case, with today’s modern presses and the accuracy of IPA/Fount doser systems, the attraction of a one pack fount/alcohol product loses its novelty and if you can’t mix a crude solution by hand to run a press, why are you in this job? Incidentally, see they claim to help clients to go continuously greener, importing by the container load from South Africa gives it a HUGE carbon footprint!!! Other problems encountered were steels inking up constantly, needing to be cleaned several times per shift, we also used to get a crystallisation around the pipe joints on the main tank. Did have some excessive plate wear, probably a third down on normal run lengths but you may not notice if you have run lengths of less than 10,000. Don’t know if this was due to the crystallisation. Biggest complaint from the minders was the smell, god-awful! We had a problem running a job with a 300 screen, just kept losing the dot. Cleaned the tanks and went back to fount and IPA and although not perfect, gave a better result. Never went back to 2in1 after that. Nail in its coffin was the price, far more expensive than fount/IPA for the possible benefits so the M.D. decided to knock it on the head. Sad to say, the company closed shortly after. In today’s recessionary climate, even more essential to watch the cost of consumables. Not sure about the FOGRA certificate, looks a bit suspect with the high Nitrate content? The MSDS looks a bit evil, probably no more than IPA though. As a now redundant lithographer, anyone interested in a decent hands on machine room manager, please get in touch! Good luck in any case. Don't know if this helps with 2in 1, any questions, please ask, see if I can remember anything else.
