Another MacPro in the room is experiencing crashes on startup of Acrobat 9, which was part of CS5. It was set to bypass the startup screen, so I don't know what it's trying to do when it dies. Here's what I did:
Uninstall, then reinstall. I started it up and it seemed fine: opened files, changed preferences. Then I reinstalled a set of plugins we use from Heidelberg - PDF Toolbox. And I couldn't open Acrobat after that. I remembered we had another problem because the OS was 10.6.x, and Heidelberg claimed that version of Java was too new for the version of their software that we use. We reverted to 10.5.8 for the MacPros that do most of that work. The MacPro with the crashes uses 10.6.8. I thought that a conflict between Java versions might be causing this issue also.
So I uninstalled the plugins, uninstalled Acrobat, used Onyx to clean out caches, rebuild Launch Services and reset permissions; restarted the Mac, reinstalled Acrobat - but it still crashes on startup.
It was working (for quite a while), then it wasn't. It's not my machine so I don't know what changes were made recently. I'd appreciate guidance on what path to take to diagnose this. I've copied the beginning of the crash report below.
Process: AdobeAcrobat [382]
Path: /Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat
Identifier: com.adobe.Acrobat.Pro
Version: 9.3.0 (9.3.0)
Code Type: X86 (Native)
Parent Process: launchd [96]
Date/Time: 2011-07-07 12:13:57.132 -0700
OS Version: Mac OS X 10.6.8 (10K540)
Report Version: 6
Interval Since Last Report: 195 sec
Crashes Since Last Report: 1
Per-App Interval Since Last Report: 6 sec
Per-App Crashes Since Last Report: 1
Anonymous UUID: FDF375E0-CD77-4C6E-9F94-6079924FF389
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000001798e002
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
Report Version: 6
