Address labels on Ricoh C900
KCrom
Is anyone running diecut laser labels on their Ricoh C900 successfully? And if so, what brand(and settings)? I asked my local rep for suggestions and they just pointed me to the Ricoh "stock list" that only shows one brand of label tested, and it is a Spinnaker 12x18 sheet, which does me no good.
Check with your Ricoh systems engineer, not your sales rep. A new recommended media list was just published on 5/18, with several new entries for Lazerdox label stock.
FYI, I just ran 600 sheets from Discount Labels though my Xerox this weekend without any issues.
NLprintguy, the recommended media list is not published to the web, but is distributed within Ricoh PPBG, mainly to the PPSEs, who in turn should be distributing it to their customers. The latest list was just published, so should take some time yet to filter out. Rather than waiting, perhaps you should call your Ricoh PPSE or PPS or other rep to inquire about it. The new label configurations that were added to the list are all from Lazerdocs.
In the EU a number of die cut labels have been tested.
Fasson High Gloss Crackback
Label Jet
CLP Adhesive HT CL
CLC Adhesive PCL
Value Peel White
A number of plain lables produced by PCL Labels have also been tested recently with good results.
When testing labels remember NOT to duplex them and select FACE UP printing in the Finishing tab within the Fiery / Creo controller.
Pro C900 Media List
Pro C900 Media List
The Pro C900 media list is published on the Ricoh Europe web site : https://eu-ricoh-en.custhelp.com/cg...y5zZWFyY2hfbmwmcF9wYWdlPTE!&p_li=&p_topview=1
Ricoh's European Media Qualification Centre in the UK publishes results regularly (at least once a fortnight) however there may be a slight lag before those results are available on the web.
