jdr999 The profile is mainly about fixing, so it has a lot of Action Lists involved.
I can edit them and send you a specific profile for your needs.
Just to clarify, you would like two changes.
1. 0.25" bleed instead of current value (3mm)
2. No adding of Crop Marks.
Is that correct?
I'm still an advanced beginner when it comes to PitStop. So no, I don't do very much that isn't already setup.Ok. Do you have any experience creating or editing Action Lists in PitStop?
Do you create your own preflight profiles at all?
Just wondering if it might be better to explain how you can edit the settings yourself.
Here you go, here's a version without Crop Marks, adjusted Bleed and the color conversion is to Web Coated (Swop) v2. this is also the output intent.
I haven't had the opportunity to test it as I am on vacation now until the 18th July. Have a play and if changes are needed then I can do them when I get back, or maybe someone else on the forum can assist.
https://esko.box.com/s/w7kpsgnfhkx6317ccvmeobhvnm8htcm6
