Algae in the Water System
Cornishpastythighs
we used bleach when I was running a newsprint web press, did a thorough clean of the Dampening System every week and the stuff that came out looked liked new life forms
Cornishpastythighs
Press chiller system needs rust inhibitors and glycol if its a closed system, press fountain system can be cleaned with bleach. flush system with warm water and mild bleach liquid. Make sure system has been flushed again with clean water before filling with fountain solution chemistry
turbotom1052
Most modern fountain solutions have an algicide mixed into their formula. If its not enough, you might ask the manufacturer to either mix you a special batch with more in it, or get suggestions from them as to what to use.
Zerge
for a Press Water Chiller
Canon Research
Canon
ENHANCING THE PRINT CUSTOMER CONNECTION
Delivering Client Experiences That
Build Competitive Ad-vantage
Download the White Paper
