Avantra 30 short OLP - Error 61
gicbelgium
Hello,
I get an error message directly after the boot up sequence > error 61 : No carriage encoder mix.
I check the mouvement of the carriage and no parts (flappers or cable) stops the mouvement.
The carriage comes to home position and after it moves a bit to the center of the drum.
Directly after the error 61 appears.
The Analog encoder could be defective?
Anyone could help please?
Home sensor can't be an issue as VladCanada mentioned. Let's try the Flat Cable and press the connector firmly to the carriage board for now. That could be the problem.
